Acumuladores, pilas / baterías, cargadores, condensadores, filtros, protección contra rayos y sobretensiones equipos de protección, bancos de carga, rectificadores, tiristores, transformadores, transformadores de corriente, energía de reserva y UPS (estático, rotativo, etc. diésel).
Hola foreros,
tengo una furgoneta camperizada, o sea, con vivienda en la parte trasera. La instalación eléctrica me está dando problemas, y estoy pensando cambiarla entera (que da menos dolores de cabeza que andar parcheando).
Básicamente, el sistema es de doble batería, es decir, hay una batería secundaria que alimenta la vivienda (luces, bomba de agua nevera, cosas así; tb enchufes de 220 a través de un inversor) y que se carga a partir de la batería principal cuando el vehículo está en marcha, con un relé en medio. Hasta ahí mis nociones sobre todo esto XDDD.
Quisiera saber si alguien tiene por ahí un esquema un poco digno de este tipo de instalaciones. He visto alguno casero por ahí, pero no me fío mucho (en el país de los ciegos...).
Os lo agradecería mucho!
seo company
 A man was going to the house of some rich person. As he went along the road, he saw a box of good apples at the side of the road. He said, "I do not want to eat those apples; for the rich man will give me much food; he will give me very nice food to eat." Then he took the apples and threw them away into the dust.
  He went on and came to a river. The river had become very big; so he could not go over it. He waited for some time; then he said, "I cannot go to the rich man's house today, for I cannot get over the river."
  He began to go home. He had eaten no food that day. He began to want food. He came to the apples, and he was glad to take them out of the dust and eat them.
Replace bad influences with positive ones
 It is vital that you become aware of external poor elements to your life which may be conserving your mind hostage. as an instance, your intellectual country can come to be toxic by being round buddies who're terrible. in case you aren't vigilant sufficient, you will start to undertake their thoughts as your very own. therefore, be alert to what your bad affects are. if they arrive from certain buddies, restriction your publicity to them as much as you may. refrain from discussing your plans with folks
who will be unsupportive of your dreams and goals. copyright dedecms
As a substitute surround your self with mind and moves from folks who will empower you.
best seo company
