Pues eso, estoy instalando Autocad 2006 y 2008 y no me deja instalarlos, cambie hace poco al windows 7 y no se porque no me deja, en el pc de mi novia lo instale tambien el window 7 y me dejo instalar el cad.
El fallo que me pone para los dos CAD (06-08) es similar y es este para el 2006:
[3/30/2010 12:02:49] === Installation started on LOPEZ-PC by lopez ===
[3/30/2010 12:02:55] [Info] Windows Installer upgrade is not required
[3/30/2010 12:02:55] System Version = 5.0.7600.16385
[3/30/2010 12:02:55] Installation skipped: MSI Runtime 3.0
[3/30/2010 12:02:55] [Info] .NET Framework Runtime upgrade is not required
[3/30/2010 12:02:55] System Version = 2.0.50727.4927
[3/30/2010 12:02:55] Installation skipped: .NET Framework Runtime 1.1
[3/30/2010 12:02:55] Installation started: .NET Framework Runtime 1.1 Language Pack
[3/30/2010 12:02:55] Command = "C:\Users\lopez\Desktop\07 - AutoCAD 2006\Bin\AcadFEUI\support\dotnetfx\esp\langpack.exe" /q:a /c:"inst /qb"
[3/30/2010 12:03:03] [Error: 1603] Error irrecuperable durante la instalación.
[3/30/2010 12:03:03] Installation failed: .NET Framework Runtime 1.1 Language Pack
[3/30/2010 12:03:03] Installation aborted
[3/30/2010 12:03:10] === Installation ended ===
Y para el CAD 2008 este:
2010/3/30:12:14:32 lopez LOPEZ-PC === Setup started on LOPEZ-PC by lopez ===
2010/3/30:12:16:08 lopez LOPEZ-PC Install .NET Framework Runtime 2.0 Language Pack Failed Failure is ignored, Result=193
2010/3/30:12:16:32 lopez LOPEZ-PC Install DirectX 9.0 Runtime Failed Failure is ignored, Result=-21
2010/3/30:12:16:33 lopez LOPEZ-PC Install MSXML 6 Succeeded
2010/3/30:12:16:38 lopez LOPEZ-PC Install MDAC 2.7 Succeeded
2010/3/30:12:16:41 lopez LOPEZ-PC === Setup ended ===
Que ocurre??? A alguien le paso???
graciasssss
Última edición por maloga el 02 Abr 2010, 13:04, editado 1 vez en total
Prueba una cosa:
Prueba a desinstalar primero .NET Framework de tu equipo antes de instalar AutoCAD. Autocad te los instalará.
KTURKK escribió:Prueba una cosa:
He borrado todo lo que se le parece a .NET Framework, bueno he puesto en inicio-buscar-.NET Framework y eliminar todo lo que he podido, pero aun asi me sigue dando fallo.
Me he podido equivocar al no borrar bien o se me pasa algo??
Tienes que desinstalarlo desde panel de control/quitar programas.
KTURKK escribió:Tienes que desinstalarlo desde panel de control/quitar programas.
Ahora igual no puede hacerlo así, si es que ha borrado directamente la carpeta....
1. Hablen con AUTODESK y comenten el problema.
2. Leer normas del foro.
Y por favor cierren el Post, antes que nos cierren el foro.
Sir Maky escribió:1. Hablen con AUTODESK y comenten el problema.
Nadie había hablado de "PIRATEAR" hasta que tú lo has insinuado.
El usuario que planteó la duda, puede ser que haya comprado el programa. El usuario tiene muchas ganas por comenzar a trabajar con él, y los de Autodesk están de vacaciones durante semana santa.
No seemos tan mal pensados.
Un último apunte: Una cosa es hablar sobre un tema y otra es dar links de descarga. Por lo segundo se cierran páginas pero por lo primero no.
Todos tranquilos, no seais mal pensados.
Como han dicho anteriormente, nadie ha hablado de pirateo ni nada, tampoco se han colocado links de nada, no se donde esta el problema.
Siguiendo el hilo, aun sigo sin poder instalar el dichoso CAD.
Tendre que informar a mi informatico particular, jjeejej, vamos un colega ing. informatico, jajajaja.
De todas formas muchisimas gracias.
Si no les dare un toque a autodesk.
